ok, not to brag (i overpayed for it by about 300 dollars), i have an rtx 3080ti in my system, now to make back the money i lost to the scalper, i want to use my gpu to mine idly in the background while it is not being used, can someone pls recommend the best software to do this and where i can get it?
Imagine everything i have written in a Linus Voice/ linus tone (Spock live long and prosper gif here ,idk why tho, i guess i just want to say that i like star trek and am waiting for new seasons of the ongoing shows), But seriously, a lot of what i type only makes sense when said in a Linus tone from an older ltt video (circa 2017-2019 & now 2024-onwards) basically before he got a beard and a lot of it should make sense even in a Linus with a beard face.
also note as per the latest typing test on my laptop, my accuracy is 69%
I'm not weird/creepy, I'm just observant I have ADHD and am not on any meds for it because I don't want to and don't need to be on meds. i also may just be depressed. If you find other things around you depressing, are you depressed or are you surrounded by depressing things?
https://linustechtips.com/topic/1404984-idle-mining/
Scalp it to someone else for $100 more
Depends on what you want to mine.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1404984-idle-mining/#findComment-15214740
You have to consider electricity costs as well. Its honestly not a great idea to mine on a card you are going to actively use and if its just background mining its literally going to take you years before you reach anysort of value.
https://linustechtips.com/topic/1404984-idle-mining/#findComment-15214780
Get a miner and turn it on/off yourself, or get something like NiceHash. It depends on what you are after and which coin you want to mine.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1404984-idle-mining/#findComment-15216114
To expand on what @tikker said - if you want simple user experience most likely NiceHash is good. If you want to maximize your own share, a better option is to mine ETH on 2miners and be paid in btc (this way is more anonymous and the BTC/NANO will arrive to your own wallet, but requires you to setup the wallet, miner & overclocks yourself). If you want to add some more utility to the 2nd setup - you can check out the CryptoCom App and their Visa offering, allowing you to mine into that wallet and convert the BTC to your local fiat on a prepaid visa (if available).
https://linustechtips.com/topic/1404984-idle-mining/#findComment-15220527
