Magnetically wall-mounting am extender
Solved by Radium_Angel,
Just now, stefanmz said:Well I was thinking if magnets are not possible drywall anchors but how am I going to hang it on the drywall anchors. It's not a painting it doesn't have mounting points at the back it's probably flat so?
Every power strip I've ever seen (at least in USALand) has screw hole mounts on the back.
If yours doesn't have that, then whatever you use, will damage the drywall (velcro mounting take, glued magnets, etc) when you try to remove it.
If you don't care about that, then velcro tape might be a better bet, full length of the power strip and matching length on the drywall
https://www.homedepot.com/p/VELCRO-Brand-4-ft-x-2-in-Industrial-Strength-Tape-90593/202261931
