My pc crashed and it refuses to turn on.
My gpu has 1x6 pin and 1x8 pin. If the 6 pin cable from the psu is connected in the slot with 8 pin, the pc doesnt even start the fans.
If i connect 6 pins in the 6pin slot and the remaining 2 pins at the end of the 8 pins slot, pc starts but my display is black.
I dont have a cable that connects the display to the mobo to confirm that the system POST and boots.
Sounds like there's a short in the GPU so the power supply short circuit protection is kicking in.
You could try unplugging everything *but* the GPU and jumpstarting the PSU to see if it turns on even with that.  If the GPU has a short the PSU won't turn on for more than a second.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
