GTX 770 Cooler
Go to solution Solved by SAV1OUR,
thats a reference one for some reason the 760 and 770 still have the old gen stock coolers
I have a standard PNY GTX 770 (http://www.amazon.com/gp/product/B00CZ7Q028/?tag=linustechtips)%C2'> i'm wondering if it has a stock PCB. If it has an aftermarket PCB, will I be able to stick a stock titan style cooler on it? Or how about an aftermarket cooler or a watercooling block?
Build: Fx-8120@4.1ghz,  Gtx770@1.0ghz,  16gb Patriot memory,  Cheap case from thermaltake
https://linustechtips.com/topic/140337-gtx-770-cooler/
If it has a reference cooler then it's reference. You can use something like the Kraken G10 to water cool the chip.
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872844
hang on is it with pnys cooler or reference  cooler?
Specs
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872845
That is a PNY cooler, the reference cooler looks like the cooler on the titan
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872850
you lost me dose it look like a titans/780/770s cooler or this?
Specs
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872861
Here is the card i am talking about. http://www.amazon.com/gp/product/B00CZ7Q028/?tag=linustechtips
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872881
Specs
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872886
That's reference
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872888
Oh, thanks! So that means i can slap any 770 compatible cooler on this thing?
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872904
nzxt g10 arctic coolers etc anything that says it works with reference 770 pcb
Specs
https://linustechtips.com/topic/140337-gtx-770-cooler/#findComment-1872907
