Budget (including currency): 2000$
Country: canada
Games, programs or workloads that it will be used for: casual gaming
This build is complete, it was the first PC I've ever put together. Here is my setup:
Corsair 4000D airflow case
Ryzen 5 5600x
B550 tomahawk
Aorus RTX 3060 elite
1TB WD SN750 ssd
2TB Seagate 7200rpm HDD
2x8gb G.Skill trident cl18 RGD 3600mhz
650w thermaltake BX1 power supply
https://linustechtips.com/topic/1403317-first-pc-build/
Looks really nice!
Only thing I can think of is you might want a better cpu cooler as that looks like the stock one and I found mine to not be that quiet under load. Really only if it bothers you.
only a nitpick.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1403317-first-pc-build/#findComment-15202908
Country: canada
Ryzen 5 5600x
B550 tomahawk
Aorus RTX 3070 elite
1TB WD SN750 ssd
650w thermaltake power supply
Isn't the recomended PSU for the 3070 a 750W unit?
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
https://linustechtips.com/topic/1403317-first-pc-build/#findComment-15202909
I believe 650w is the recommended, it seems to be working really well. Just need to unlock the ram as it's at 2666hz now. The idea of the PC was for it to be good at 1440p gaming.
https://linustechtips.com/topic/1403317-first-pc-build/#findComment-15202918
