I have phantom 410, Asus direct cu gpu , stock CPU cooler.
Front: 2x120, restricted by carbon filter and HD cage
Bottom: 1x120 restricted by metal with circular holes in it and magnetic dust filter
Side: 1x120 or 140 restricted by same metal as bottom but with carbon filter
Top:2x 140/120 restricted by relatively open mesh
Back 1x 120 restricted by hex mesh
Fans: 2x 120 bitfenix spectre pro
2x corsair sp 120 we
1x Silverstone ap 122 (120)
2x nzxt performance 120 fan (bad)
1x nzxt performance 140 fan
Where do I put what fans for best air flow?
https://linustechtips.com/topic/140324-best-airflow/
And what's your question?
Were to put what fans for best airflow
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872617
That's a nice list of fans you have there, but what should we do with it?
See above and now edited post
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872623
I'm confused as to what you're asking?
The topic doesn't really give much to go on, and there's no question in your post.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872625
See above and edited post!!!
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872631
Put them wherever you can, lol.
I can put then anywhere.
Now can I please have a helpful post??
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872662
x2 120mm Corsair SP120s on Front [Intake/Pull]
x2 140mm/120mm BitFenix Spectre Pro's on Top [Exhaust/Push]
x1 120mm Silverstone on Back [Exhaust/Push]
Those are really all you need, but throw the NZXT 140mm/120mm on the bottom if you want. Just keep a balanced airflow. The easiest way, is to draw imaginary lines with your hand projecting where the wind will travel.
But, if I was you, I would buy the twin pack of the Corsair AF140s and put them on top and move the Spectre Pro on the back. Put the rest of them away.
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872680
On top, on the side if possible.
I prefer having more exhaust fans than intake fans.
That be bad, negative pressure= dust
But I have more fans than my case can hold.
I want someone to tell me what fans should go where_.
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872684
x2 120mm Corsair SP120s on Front [Intake]
x2 140mm/120mm BitFenix Spectre Pro's on Top [Exhaust]
x1 120mm Silverstone on Back [Exhaust]
What about side?
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872687
Exhaust for the side, get all that hot air produced by the GPU and CPU out.
That would make negative air pressure tho. I don't want more exuasts than intakes.
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872706
Nope. Your intakes are filtered. Where should the dust get into your case?
What about side?
Thats really controversial: I read articles that show an improvement of the temps, and I read some that prove the opposite. In the end it just makes your PC louder, and even in the best case, only brings up to three degerees improvement. Just stick with the setup MrYuriy recommended.
Molex to SATA, lose all your data
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872724
OK.
But I'm saying with the first thing if the side was exhaust , there would be negative pressure and she would be sucked in though all the unfiltered holes in back of case
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872732
What about having the majority as intake (front and back) then just make the top as exhaust seeing that heat naturally rises anyway and the side can just be passive because of the GPU you're using. I mean not much to say because of the type of chassis.
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872734
Wouldn't back intake be useless? It would go in and immediately be sucked out top.
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872742
Ok I think I'll go
Corsair on top
Bitfenox on back
Nzxt on side (whatever IDC)
Nzxt on bottom
Bitfenix on bottom front, Silverstone on top front
Any problems (this was based off looking best thorough window, noise isn't that big of an issue for me now
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872777
It's all about balance. You don't want a bunch of fans that barely serve any purpose besides making a bunch of noise and if you're worried about dust, yeah you'll need that positive air pressure. Here's a suggestion: get a side pic of your pc and throw it up in ms paint or whatever and try planning the most effective way it can work with only the fans that you NEED. Use blue lines to represent cool air and red as warm air and whatnot and it'll work out fine.
https://linustechtips.com/topic/140324-best-airflow/#findComment-1872793
