This happens every time...
I don't want to discourage you from learning and experimenting but please remember that youtube videos like this are mostly for entertainment. This is not going to be a practical or stable setup for you.
INFO   : Opening ISO Windows11.iso...
ERROR  : Cannot bind argument to parameter 'Path' because it is null.
INFO   : Log folder is C:\Users\1996p\AppData\Local\Temp\Convert-WindowsImage\1b0aa4c7-0a9f-411a-869c-9a0462d2faab
INFO   : Closing ISO...
INFO   : Done.
Failed to create VHDX, stopping script
I am getting the same issue
This issue is discussed on the GitHub post under Notes.
  • If you get "ERROR : Cannot bind argument to parameter 'Path' because it is null." this probably means you used Media Creation Tool to download the ISO. You unfortunately cannot use that, if you don't see a direct ISO download link at the Microsoft page, follow this guide.
I did not use the media creation tool, I used the one from Microsoft website. I tried a couple different ones.
