Hey guys! So, I'm trying to overclock my i5-4670K. I have a H100i, so temperatures are mostly not an issue. I want to overclock my CPU as much as is safe, but I'm having a bit of trouble. I tried 4.4GHz with Vcore 1.200V and Vrin 1.9V. I run IBT for 50 rounds and everything is stable, but when I restart my computer it gets stuck on my Gigabyte "Insist on Ultra Durable" screen. It doesn't do anything from there. This keeps happening to me and I have to short the Clr_CMOS pins to start my computer again. So, I think I'm doing something wrong :P I know, Linus' video, but it was all greek to me. I need someone to guide me through step by step.
Specs:
i5-4670K
Gigabyte GA-Z87X-D3H
H100i
I got a blue screen. What should I change to make it stop bluescreening?
If it freezes, I decrease voltage, right? so do i increase voltage when it bluescreens?
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/140246-overclocking-help/
Are your components new? Did you check if they are all fully stable? Eg your ram.
Bluescreens can tend to be ram instability.
Did it happen after you reverted to stock?
Does the issue persist even after you cleared cmos and reentered the oc?
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1871649
Bump up the voltage to like 1.25V or something, 1.2V is very little especially if you're trying to overclock to 4.4GHz.
i9-6930X @ 5.3GHz | ASUS Z1007-A | 64TB G.Skill Ripjaw XIV 2400GHz RAM | GTX 1080 Ti | Corsair 900R
Corsair CX2500 W | 15TB WD Green | Noctua NH-D24
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1871652
Overclocking is very simple, just stick the multiplier to the wanted clock and keep bumping up the voltage until you feel its unsafe. If it keeps crashing lower the multiplier until its stable.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1871684
don't you find it strange that he can do 50 rounds of ibt?
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1871689
Specs:
i5-4670K
H100i
although it is for a 1155, it'll do for your 1150/Haswell CPU
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1871706
I do, but I still find 1.2V low, there's no real harm in trying to up the voltage a bit.
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1871728
if it is stable (use other synthetic benchmarks and real-world usage) and under 85°,
yeah it is good.
It's a little bit above 85 max, around 87-88 max with 20 rounds of IBT. Is that still okay?
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1872193
i'd say fail. although in real-world, it'll never get that warm, but the parameters of
a good stable overclock would be no BSOD, lockups or crashes and stay under 85°.
you can call it fine for a couple of degrees, but to me it is not.
are the fans running as if you were to use it for 24/7? or jacked up 100%? it'd be ok
for a bonzai "look what i got" number, but for RW too warm.
are you using the Intel Burn Test or the Intel Extreme Utility? get XTU instead. XTU
is more useful and has Haswell in mind for testing. IBT is P95 on algorithm steroids.
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1872242
The fans are actually running at the lowest i could get them. I can easily turn them up.
I'm using IBT. I'll try that  XTU thing out.
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1872315
Haswell overclocking is Very much different that previous generations.
Check out my Haswell OC guide.
http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1872714
IBT isn't really good indicator of stability with Haswell. I had it stable on it and then I ran OCCT, crash just after 5mins. I agree on volts being bit on low side at OP.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/140246-overclocking-help/#findComment-1874530
