Help! Water blocking a Sapphire 6900xt TOXIC
Solved by Redbearin,
8 hours ago, TrigrH said:You need a toxic compatible waterblock, your fault for not doing enough research.
Double check, this is my 10 second google:
It’s my fault for trusting the Micro Center guy??? What’s the point of even trying to help if you are just going to be a jerk about it?
I had already found this before I posted, I don’t order off Ali express, the last time I did I was scammed (luckily didn’t loose more then $20). Everyone I know that has ordered off Ali has been scammed lol. The eBay seller looks legit though, I couldn’t find a single real review on this water block and have never heard of the brand.
