ATX12V vs EPS12V dilemma
No.
The 8 pin cpu connector is EPS and it comes from servers. It has migrated to regular home user computers at some point. The connector is KEYED, so you don't insert pci-e connectors into it. By key, I mean the shape of the holes:
In the old days, ATX power supplies came only with the 20 pin / 24 pin connector and molex / floppy connectors.
In the times of Pentium 4, because the Pentium 4 was so power hungry, the organization that made the ATX specification released a new version of the specification which introduced the option for motherboard manufacturers to use a 4 pin CPU connector which gives 12v to the circuit which powers the processor.
So this "extended" specification was called ATX 12v ... but because the only significant change was the introduction of this 4 pin CPU connector, this CPU connector got to be called by some as the ATX12V connector / header / cable, whatever.
See the specification, on page 6-7 and on page 28 : https://xdevs.com/doc/Standards/ATX/ATX12V_Power_Supply_Design_Guide_Rev1.1.pdf
Quote1.2.1. ATX12V
A new superset of the original ATX power supply has been defined. Named “ATX12V,” this new power supply is comprised of a standard ATX unit plus the following enhancements:
• Increased +12 VDC output capability. Motherboard components with unique voltage requirements are increasingly expected to be powered via DC/DC converters off the +12 VDC power supply output.[...]
• Power Connectors. To enable the delivery of more +12 VDC current to the motherboard, a new 4-pin receptacle/header combination—the +12 V power connector—has been defined. The presence of the +12 V power connector indicates that a power supply is ATX12V; the absence of the +12 V power connector indicates that a supply is ATX.
And on page 28 you'll see the 4 pin shape, which looks like this :
You will see that the LEFT half of the EPS connector has the same KEY-ing, all four holes are same shape, that's done on purpose..
Power supply manufacturers can now take one EPS connector and make it possible to separate it into two halfs , 2 4 pin parts, and you can use one 4 pin part to plug into a motherboard that only has a 4 pin CPU connector.
When processors got even more power hungry, motherboard manufacturers adopted the EPS connector from servers and brought it to regular motherboards, they didn't invent a new standard.
So... computer power supplies have EPS connectors.... the 8 pin CPU power connectors. SOME 8pin CPU power connectors MAY split into 2 4 pin pieces, to allow someone to power a motherboard that has only a ATX12v 4 pin CPU power connector.
Am I clear enough ?
