PC upgrade / replacement
thanks.
so just to make sure, if i am not buying a 4770K or a new HDD and not going to replace my gpu (sadly) should i get the sabertooth or is it a waste?
should i get the cooler master over the noctua?
and should i really wait for intels new Devil's Canyon or whatever? its seems like something worth waiting for if it will be within my price range but im not sure.
It's a waste~ Look at my rig, I use GD65 with 4770k~ if you dont want to replace GPU you can always goes 2 way SLI~ though I'd suggest selling it and buy a new single powerful GPU more than SLI.
Whichever you want. The review on the CM 212 Evo is really good, I do remember that Noctua is good as well but I'm more familiar with the case fan of Noctua than the CPU Cooler
Well... if you current rig still work for you then yeah, if's not then there's no point waiting. For all that's matter we dont know anything about Devil Canyon yet, and then we will need to wait for Mobo and potentially other stuff, so...
