Hey guys looking for advice on the best aio for a 12900k
Im currently running a 12900k with a coolermaster ml360 v1 and its ok at cooling but not optimal.
When running a bench my temps sky-rocket all the way up to 98°c with the cpu being undervolted to 1.2v unrestricted the cpu thermal throttles big time reaching 100°c very soon after starting the bench mark.
My pump is running at 2000rpm
fan curve is quite aggressive
Mainly looking for a aio 360mm
For specifics im running
12900k
Cooler master Ml360 v1
The paste is thermal grizzly kryonaut
3080 ti ( is it normal for mem temps to be reaching 102°c when running a complex 3d render)
32gb of 3200mhz running xmp
1000w psu
6 fans in total 3 intake 3 exhaust
https://linustechtips.com/topic/1401854-best-aio/
12900k
1000w psu
A 12900K is a hot runner, no doubts about it... what case & motherboard are you using?
The VRAM at 102°C is a bit toasty & tends to indicate poor airflow... hence looking at the case.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1401854-best-aio/#findComment-15192904
I believe the case is a mb530 coolermaster. And the mobo it a z690 msi gaming edge ddr4 I believe.
https://linustechtips.com/topic/1401854-best-aio/#findComment-15193038
I just completed a build with a Corsair H150i elite and it’s fantastic. Are you setup with the AIO fan as fresh air intake or are you using it in a top mounted exhaust position? Ambient air temp? I’d guess the case is seeing negative pressure if you have 3 fans on the rad as intake and the other three as exhaust.
Overall my temps are a lot lower in a 5000d airflow, 5900x, 3080 ti, with 10 total fans (6 intake 4 exhaust).
https://linustechtips.com/topic/1401854-best-aio/#findComment-15193062
Yeah the intake is 3xfan with rad at the front. 2x exhaust top and 1x exhaust back, ambient varies but makes little difference in cpu temps when looking a hwmonitor.
Usually anywhere between 23°c and 28°c.
When I was running a 9700kf had no issues with cpu or gpu temps, I guess the extra heat the cpu is pumping out isn't contributing well to the gpu
https://linustechtips.com/topic/1401854-best-aio/#findComment-15193065
Ek's AIOs are great i just put the 360 Basic in my build, the stock fans are a bit noisy at high RMP (i swapped them out for Lian LI SLs). a 5800X with a modest overclock under 100% synthetic load hit a max temp of 71C with a sustained load of around 20 min or so (inside a 4000D airflow), at idle when the pc is dead silent im at 30C
https://linustechtips.com/topic/1401854-best-aio/#findComment-15193550
