need help with prebuilt pc
46 minutes ago, Atishay said:Q1. Do prebuilt pc last for as long time as building yourself considering that they use poor quality of motheboard and psu ?
Q2. Pls suggest some good software(free) to test if it is being thermal throttled , and other things to consider while buying prebuilt pc
Q1
Depends on the manufacturer but they generally suck ass, quality and/or value. Some have really good quality but stupidly overpriced pcs, some have really good value but terribly built pcs, some have both good value and quality
Q2
Personally ive used throttlestop for that, you can pretty much yeet power and current limits out the window by playing around in the tpl menu. Though for a proper monitoring program then id suggest hwinfo64 cause tons of sensor data. For a stress test program ive personally used furmark and prime95 though im still on 775 so these programs are well suited for me, for newer systems i think furmark is too stressful and can actually burn some gpus, replace with a benchmark tool like heaven benchmark or superposition. And prime95 could be considered a "power virus" so the cpu might throttle itself anyways, idk what to replace it with since cb isnt a rock solid stability indicator
If youd like a best of both worlds build where you can choose the components without overpaying for them and actually choose the entire build and not just a few things w free choice of parts and also not wanting to be inconvenienced by building it yourself then id suggest buying all of the parts yourself and have someone build it for you
