Scratch code help
Go to solution Solved by tikker,
Have you made a list first? Doing a quick check online those blocks only show up once you make a list variable.
13 minutes ago, Agena_ said:
Or what this code will output?
Those code blocks quite literally tell you. At the end it will  "say",or output, the 7th item in the list.
Hi im trying to learn scratch, i wanted to know what this code would output 12
I tried making it on scratch 3.0, but the 'delete all of list' / 'add to list' / item 7 of list - arent on scratch, i couldnt find it
The reddy orange blocks.
Does anybody know how i can import the reddy orangy blocks.
Thanks
https://linustechtips.com/topic/1400948-scratch-code-help/
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1400948-scratch-code-help/#findComment-15186700
thanks it worked. appreciate it
For these 2 images i attached. Do you know how i can test if they will return true or false?
https://linustechtips.com/topic/1400948-scratch-code-help/#findComment-15186723
That comes down to you knowledge of math and logical operators. = (or == in most lanugages), > and < check for equality, larger than and smaller than. AND checks if both sides of the comparison are true and OR checks if at least one side is true.
https://linustechtips.com/topic/1400948-scratch-code-help/#findComment-15186766
