Vulkan backround problems
Solved by cretsiah,
probably not the best setting with a bad connection or low spec computer.....
if i understand correctly this setting is trying to download / process / draw images to your gaming screen in real time as you play, so it will be wanting access to the same resources as your game and the internet connection at the exact same time.
have you tried just leaving it on pre-caching only?
so yes a bad/ low connection would cause packet loss. packet loss is not the same as ping.
