Help identifying my R9 390X gpu for water cooler?
First, I'm just gonna say this is a bad idea. That video card is ~10 years old and no longer gets driver support. You're gonna spend $100-200 at least on an AIO, and if you sell that card and use that money you can get 1070 or a 1070Ti, both are much better cards than a 390X. If you need Linux support (it looks to me like your running Pop_OS!) then you can get an 5500XT, thought the Nvidia card is still a bit better.
Second, what you're trying to buy isn't an AIO, it's a water block. That means you need to buy a pump, reservoir, radiator, fittings, and tubing all separately. It's gonna go up in price substantially, almost to the point that you can just afford a 6700XT anyway. This is not a great idea.
Finally it looks like they just don't make a block for that particular card.
