So I was having issues with windows 11, I was able to reinstall windows, but I noticed that it seemed when I had all my ram in the computer, it was glitching and freezing on the boot screen. When I took out my 2nd DIMM it worked just fine, and then when I put the bad DIMM in the first slot (where it was previously working with 1 DIMM) it then would do the glitch again and then I put the other DIMM back in, it would work again.
My guess is that it's a bad DIMM, maybe from electrostatic, or something unknown since virtually nothing changed and then it stopped working correctly.
I was reading online and some were suggesting to possibly bump up the voltage to that DIMM and see if that helps. Does anyone else have any suggestions before doing a return to Amazon?
The ram is Corsair Vengeance RGB PRO SL 3200Mhz 32gb 16x2
CPU is i9 7920x
MOBO is Gigabyte x299 Designare EX
https://linustechtips.com/topic/1398714-possible-dead-ddr4-dimm/
If it's me, I'll just RMA if I can RMA.
Bumping up the voltage might solve it, but it doesn't mean it's not a troubled one.
Refresh before you reply
