rtx 3060 ti RTX 3060 ti low fps (possible bottleneck)
3 hours ago, Affensohn said:So i made a 3d Mark Benchmark ( Firestrike) at least the ram is running as it should but i think the score is still pretty low..
edit: are you sure that's firestrike? because that score is about what is expected for timespy benchmark
link to the results please?
well, since it shows the link:
this is Timespy, results are exactly as expected, not "low"...
5 hours ago, Affensohn said:but how can this happen?
its because its a 1st gen ryzen and you're most likely being cpu bound...
5 hours ago, Affensohn said:i deleted it bcause someone said that it can interact with the settings of the Geforce EXperience Performance mode.
btw, this is correct GeForce Experience can interact with everything, its an unproven buggy pos and thus should be avoided at all costs... the overlay is also a bad joke, btw... use afterburner instead, it's far more accurate and gives you better control.
(but yeah dont use them together, obviously)
Tldr: you *may* be cpu bound as you already suspected as per title, but your system seems to be functioning absolutely normal, and your timespy score is also completely normal for your hardware.
