Wifi Range / Extender help
First off, get something to measure the wifi signal. Then you'll know if you're making a difference.
It's important to understand most antennas are omnidirectional, so they transmit and receive from all and to all directions. You can "improve signal strength" by focusing the beam in a direction.
You can do that with a directional antenna, a yagi antenna, or even a "cantenna"
Unfortunately the router you have doesn't have the option of an external antenna or removable antenna.
So you can either replace that router or replace the extender with something that does, and get a directional antenna.
But I'd try just moving the antennas first, using your measuring app you might be able to get a better signal.
Also, signal strength will change with the weather, so there's that...
Good luck!
