Okay so I just watched the LTT video on this and it immediately peaked my interest.
My question is what do I need to do for it? Do I need any quick sync drivers? Do I need to enable anything in BIOS? All the video explained was the OBS portion of the process and I'd be very surprised if that is all I had to do.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
https://linustechtips.com/topic/139751-intel-quick-sync-obs-help/
If you're using a dedicated graphics card, the Intel GPU will be disabled, so you can't use it.
If you're just using on board graphics (and have no dedicated GPU) just do this:
(obviously select quick sync and not Nvidia NVENC)
Okay well as I said in post I know how to enable it in OBS, my question is what all else do I need to do besides enabling the option in OBS if I'm using a dedicated gpu?
Re-enable the on-board graphics in the BIOS.
Or if you have an Nvidia GPU just you Nvidia NVENC
Yea I have Nvidia but I don't think NVENC will take as much load off my cpu and quick sync will.
Okay so on my z77a g45 board I only get the option to choose from either pcie graphics or integrated, if I enable integrated my screen won't display when attached to my 770. I believe the option to get around this is igpu multi monitor or something correct?
NVENC uses your GPU to encode the video. you drop 10% of your fps MAX
Sweet I got it working, just enable igpu multi monitor and download the drivers.
Case: CM Storm Trooper I CPU: 4770k @4.5ghz I Cpu cooler: H110 I RAM: G.Skill Sniper 16gb 2400mhz I GPU: Sapphire 7970 OC I Mobo: Msi gd65 I PSU: Corsair rm 750w I KEYBOARD: Cm Storm Trigger cherry mx blue I MOUSE: Corsair m65 I MONITORS: ASUS VG248QE 24" 144Hz and Acer X223W 22" 60hz I AUDIO: Corsair vengeance 1500
The drivers for integrated I assume?
Yeah depending on what 3000-4000- series graphics you have. BTW to get it to encode without crashing you have to open another virtual display. If anyone needs help>
