Hi guys i need help. I dont know what pieces i should get for my pc. I have around 3000 $ CAD budget ( I can go max to around 3.5k CAD) but i want to lower the price i have right now. ( I DONT CARE OF RGB) please upgrade this build https://ca.pcpartpicker.com/list/9XMnsX
- I want a motherboard that supports the CPU ,with wifi, m.2 slots, 4 ram slots ddr4
- I want good 360mm AIO cooler
- I want fast 32gb ram ddr4
- I want 2tb of m.2 storage if possible but if not 1tb
- You can change the graphic card but if you do please send me the link of where i can buy it
- I want good fully modular power supply that will give me more power than i need in case i want to update later.
- I need a good case for all my componants that will fit everything inside of it ( ONE WITH GOOD AIRFLOW)
- dont change my monitor
PLEASE HELP since its my first pc i dont know what are the best componants
https://linustechtips.com/topic/1397366-help/
Here is my edit.
MSI motherboard is really good one with good features, I don't really recommend getting Asus prime one.
Most of parts you listed are good, But I made few edits. Changed AIO and case, It doesn't sacrifice performance at all, Only downside is you won't have corsair Icue to control RGB, Nothing more, But it saves lot of money, So you decide, If you are willing to pay extra for better RGB software, You could do that. Upgraded your SSD to a lot better 2TB one. And since even 650w will be enough for this system, Saved some money on PSU as well.
P.S. Buy windows key from cdkayoffers or from ebay... That'll cost you around 20 bucks.
PCPartPicker Part List
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  ($499.98 @ Best Buy Canada)
CPU Cooler: ARCTIC Liquid Freezer II 360 A-RGB 48.8 CFM Liquid CPU Cooler  ($198.21 @ Amazon Canada)
Motherboard: MSI PRO Z690-A WIFI DDR4 ATX LGA1700 Motherboard  ($309.99 @ Amazon Canada)
Memory: Team T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($162.98 @ Newegg Canada)
Storage: Western Digital WD_BLACK SN750 2 TB M.2-2280 NVME Solid State Drive  ($254.00 @ Newegg Canada)
Video Card: Asus GeForce RTX 3060 Ti LHR 8 GB ROG STRIX GAMING OC V2 Video Card  ($1336.00)
Case: Cooler Master MasterBox TD500 Mesh w/ Controller ATX Mid Tower Case  ($104.99 @ Amazon Canada)
Power Supply: SeaSonic FOCUS Plus Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Canada Computers)
Monitor: MSI Optix MAG272CQR 27.0" 2560x1440 165 Hz Monitor  ($399.00 @ Amazon Canada)
Total: $3375.14
Generated by PCPartPicker 2021-12-20 03:01 EST-0500
https://linustechtips.com/topic/1397366-help/#findComment-15164076
14 hours ago, Dr0idGh0sT said:
Here is my edit.
Total: $3375.14
is cdkayoffers legit?
https://linustechtips.com/topic/1397366-help/#findComment-15165029
There's a pretty good gen 4 drive available right now if you're interested. Not really important for gaming, but it's a nice premium drive. Here's a link to it:
ADATA XPG GAMMIX S70 Blade
There is also good gen 3 drives on sale:
https://linustechtips.com/topic/1397366-help/#findComment-15165112
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($359.99 @ Memory Express)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler  ($79.95 @ Amazon Canada)
Motherboard: Asus PRIME Z690-P WIFI D4 ATX LGA1700 Motherboard  ($289.00 @ Canada Computers)
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($139.99 @ Newegg Canada)
Storage: ADATA XPG GAMMIX S11 Pro 2 TB M.2-2280 NVME Solid State Drive  ($229.99 @ Amazon Canada)
Case: Fractal Design Meshify 2 Compact TG Dark Tint ATX Mid Tower Case  ($159.99 @ Memory Express)
Power Supply: be quiet! Straight Power 11 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.88 @ Canada Computers)
Monitor: ViewSonic VX2768-2KPC-MHD 27.0" 2560x1440 144 Hz Monitor  ($344.99 @ Amazon Canada)
Total: $3019.78
Generated by PCPartPicker 2021-12-20 20:10 EST-0500
https://linustechtips.com/topic/1397366-help/#findComment-15165210
