PCIe wifi card, or motherboard Wi-Fi?
Solved by Eigenvektor,
The PCIe card has the advantage of being more flexible, since you can buy whatever you want and replace it if needed. With the built-in you'd have to replace the whole MB. But on the plus side, it's already there at no extra cost.
That being said, you're not going to benefit from Wi-Fi 6 unless you router also supports it.
Featured Topics
7
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling2 -
BotherRed ·
Posted in General Discussion4 -
2
GOATWD ·
Posted in Operating Systems8
