Budget (including currency): around 3000-3500 CAD$
Country: Canada
Games, programs or workloads that it will be used for: Games most of the time
Other details: https://ca.pcpartpicker.com/list/TK86vf
Hello guys, It is the first time that i build a PC and I want to make sure that everything is good. Can someone look to the pcpartpicker and tell me what are the problems and what should i do to correct them. And anyone knows a website that sells windows 10 - windows 10 pro keys for cheaper and that I can trust? Ty for your help 🙂
https://linustechtips.com/topic/1396589-help-with-my-first-pc/
Country: Canada
over price most of but all super fine for 1080p med-high settings / 1440p med-high settings (dlss on)
maybe can change power supply to RMX variant. good bit
https://linustechtips.com/topic/1396589-help-with-my-first-pc/#findComment-15159283
Oh god as soon as i saw the underpowered cpu i knew a sht ton of overpriced rgb is next and guess what i was right
Yea wayyyy underpowered cpu and gpu, wayyy too much corsair inferior rgb crap
https://ca.pcpartpicker.com/list/TcMLW3
Far better value w upgraded cpu + 1250cad for a gpu
Gpu wise maybe a 3060ti or 3070 instead of a measly 1660
https://linustechtips.com/topic/1396589-help-with-my-first-pc/#findComment-15159391
yeah but a 3060ti and 3070 are impossible to get tho
https://linustechtips.com/topic/1396589-help-with-my-first-pc/#findComment-15159437
Just now, Serju Iurcu said:
And why did you put the windows 10 for 20$? And i kinda want a 360 aio cooler
20$ w10 you can get from sites like scdkey, even has some promocodes for a discount, iirc tech yes city has a promocode for scdkeys
do you want a slow ricer pc with all the aesthetics but no performance aka equivalent to a ricer civic, or do you want an in between pc aka good looking but fast civic and not a slow ricer civic with a fart can exhaust?  Sorry but if you are gonna waste some money on a needlessly overkill aio then you are prob gonna have to downgrade the gpu
https://linustechtips.com/topic/1396589-help-with-my-first-pc/#findComment-15159456
Slightly tweaked your build....
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($339.99 @ Canada Computers)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($120.66 @ Amazon Canada)
Motherboard: Asus PRIME Z690-P D4 ATX LGA1700 Motherboard  ($259.00 @ Canada Computers)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($179.98 @ Newegg Canada)
Storage: Corsair MP600 Core 1 TB M.2-2280 NVME Solid State Drive  ($149.99 @ Amazon Canada)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($131.90 @ iSanek)
Monitor: Gigabyte M27Q 27.0" 2560x1440 170 Hz Monitor  ($369.99 @ Amazon Canada)
Custom: MSI Mech Radeon 6700XT + MSI MPG A650GF 650W PSU Combo ($1219.98)
Total: $2771.49
Generated by PCPartPicker 2021-12-16 22:50 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1396589-help-with-my-first-pc/#findComment-15159517
