Hello,
I'm new to overclocking and I'm interested in learning any good guides that start from 0 for new people?
End goal: To set manual overclock on workstation (3D rendering) PCs so colleagues don't feel the need to turn on Ryzen Master every time they start their PCs.
https://linustechtips.com/topic/1396151-overclocking-for-a-novice/
1 hour ago, skilja said:
Most of the systems are Ryzen (2700x, 3700x, 3900x, 5900x, 5950x), motherboards are mostly B550 tomahawks, with two x470-f. Ram is usually 16GB 3200-3600MHz.
The 2700X may OC. The 3000 series, the best you're going to get is just enabling PBO and getting a slight boost. For 5000 series, it's PBO with the curve optimizer to do a per core undervolt.
That said, you should never really mess with workstations, i.e. computers you need to get real work done on. Stability is paramount for a workhorse PC and *any* form of OC or deviation from stock introduces instability.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
