By clacky do you mean linear?
Is there a certain sound profile you're aiming for that you could link?
1 hour ago, GloriousGamer321 said:
Cant really go wrong with creams
Really any linear switch of decent quality can get somewhere in that range
20 minutes ago, GloriousGamer321 said:
like Novelkeys x Kailh creams?
Yessir
If you want something cheaper with the same weight, try Gateron Blacks
Sound profile has more to do with case, plate and dampening that the switches do. Caps also play a not insignificant role.
If you want that kind of sound I'd recommend an aluminum plate and use PE foam for dampening. Also look into the tape mod. (basically lining the back of your PCB with painters tape)
aluminum plate comes with the gmmk pro, pe foam I believe they use it for packaging, painters tape, I can buy.
11 hours ago, Slottr said:
Yessir
so the website I am at https://kbdfans.com/products/novelkey-x-kailh-linear-cream-switch?variant=39684870733963
it sells 2 types, chocolate POM and normal creams, is there a difference, which one should I get?
Doesnt matter, its just the colour of material - both are made of POM
would something like a PC plate or POM plate not be quieter?
