Two separate 6+2 pin connectors?
Solved by Oshino Shinobu,
That's fine. For higher powered GPUs, that's actually exactly how you should do it. Just tuck the unused 6 pin connectors away. I personally just use a cable tie to tie it to the rest of the cable to keep it a bit cleaner.
Featured Topics
TridentTank88 ·
Posted in Graphics Cards1 -
Nov845 ·
Sanderdrejer ·
Posted in Troubleshooting2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
