Hey everyone! Trying to fix a PC, I have no display untill I force shutdown, the it boots into the bios saying overclock failed. So I set everything to default, then try to boot again and no display. So I force shutdown and turn it back on, and it boots into the bios, again.
It doesn't boot into the bios or show any visuals at all inbetween before a force shutdown. I'm not running any overclocks at all, and memory frequency is set to auto but I've also tried the lowest it can go.
I've tried a different PSU/GPU/SSD but I haven't had any luck. Any settings someone can recommend I could flick on/off to try? Thanks a ton.
Hardware info:
A170-A
I7 6700
16gb of ram rated for 3200 (only testing with one stick)
R9 280x (also tried a 1070)
500w PSU (also tried 750w, no difference)
https://linustechtips.com/topic/1394337-need-help-with-a-boot-problem/
You can remove the BIOS battery and unplug the power cable to make sure, everything is set to default.
If "overclocking failed" it's probably a CPU problem.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Yeah I've tried resetting the BIOS, I think I have a dual core from that gen I can test. Thanks for the recommendation :)
After resetting the bios, trying a different PSU, CPU, GPU, SSD, and ram I'm almost positive something is wrong with the motherboard. Do you have any recommendations on anything else to test?
So the problem appears when windows is booting.
The BIOS is set to default.
Maybe some software installed on windows tries to overclock?
By trying different SSDs you mean testing with a different SSD with a different/fresh windows install?
If yes, there is probably no additional software causing the problem.
If no, you can try a fresh windows install.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
