Need some quick python help
SVThuh
I have most of the script.. I poached it from somewhere else.. I am no programmer, though I do want to learn..
That being said, I am trying to make this script auto increase the user input until it finds a number that does not end in "1" (Collatz Conjecture).  Is this something that's easily done?  Can it also only show the number of steps instead of the work output?
Thanks
def collatz3(inputy):
    listy = [inputy]
    while inputy != 1:
        if inputy % 2 == 0:
            inputy = inputy // 2
        else:
            inputy = 3 * inputy + 1
        listy.append(inputy)
    return listy
userInput = input('Type in a number: ')
while True:
    try:
        userInput = int(userInput)
        break
    except ValueError:
        userInput = input('That is not a number. Type in a number: ')
collatzSeq = collatz3(userInput)
print(collatzSeq)
Is this what you need?
The code will return the next number that does not end in 1 and the steps in a list ['number','steps']
EDIT: code has a few bugs will sort them out soon if you still need it
EDIT2: FIXED
def nextInt(input1):
    try:
        integer = int(input1)
    except:
        return 'ERROR'
    steps = 0
    if integer > 1 and integer < 10:
        value = [integer,steps]
        return value
    elif integer == 1:
        integer = 2
        steps += 1
        return value
    else:
        while True:
            if integer % 10 != 1:
                return value
            else:
                integer += 1
selectedNum = input('Enter a number: ')
print(nextInt(selectedNum))
EDIT2: FIXED
This doesnt seem to be working.. I was hoping to be able to say enter "5" and have it spit out the number of steps and automatically move on to "6", using the following mathematical portion of the original code:
while inputy != 1:
        if inputy % 2 == 0:
        else:
Thanks for the help!
while inputy != 1:
        if inputy % 2 == 0:
        else:
Ok I've edited it to use your calculation, the print statement will return [the number its on, the number of steps, the final value] The code will also stop when the return value is not 1. In addition I added time.sleep to slow it down between calculations to make the data readable but if you want to speed it up you can just remove that line
import time
    cont = True
    try:
        input1 = int(input1)
    except:
        return 'ERROR'
    while cont:
        steps = 0
        input2 = input1
        while input2 != 1:
            steps += 1
            if input2 % 2 == 0:
                input2 = input2 // 2
            else:
                input2 = 3 * input2 + 1
        value = [input1,steps, input2]
        print(value)
        time.sleep(0.1)
        if value[2] != 1:
            cont = False
        else:
            input1 += 1
nextInt(input('Input a integer: '))
This is EXACTLY what I needed.. Thank you.. Putting my old twin Xeon machine to work with this right now.  Works a treat!
Glad it works, happy to help
