I'm not a streamer, but for people to be able to help you should provide more information such as your full PC specs and streaming setup, streaming bitrate, settings etc.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15137838
-> Moved to Programs, Apps and Websites
Saying "great specs" and then saying "PC can't handle" means that your specs aren't so great that you can play whatever you play and encode it at the same time. Or you have wrong encoder set up. Either way, without full details, you don't be getting any detailed help either.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15139490
Hello,
these are my PC specs
CPU: 5900x
GPU: 3080
RAM: 32GB 3200mhz
Streaming settings are:
res: 1280x720 60fps
Bitrate: 4500
Thanks for your answer, I appreciate it 🙂
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15144612
14 minutes ago, qvtran said:
Hello,
CPU: 5900x
GPU: 3080
RAM: 32GB 3200mhz
res: 1280x720 60fps
Bitrate: 4500
And the encoder? Do you have same issues with recording? And what kind of issues they are? Frame drops? High CPU/GPU usage? Pixelation on stream? Buffering?
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15144644
Hi!
I'm using Nvenc new, recordings are sometimes laggy and when I stream the video is laggy and I get frame drops. 😕
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15144650
1 hour ago, qvtran said:
Hi!
Have you tried with different driver for GPU? Is the GPU working otherwise fine, getting at 80%+ usage and temps are fine? Have you tried if things are better with CPU encoding?
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15144810
How do I try different drivers? I do not think the gpu got over 80% workload, I got 70 degree celsius constantly. I have not tried CPU encoding, it is the X264 right? I will give it a try.
Thank you for being in touch with me. 🙂
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15144867
Check your current driver version, then download either version or two older, or beta driver and install that one. Or if you aren't on newest driver, try with that first.
This would mean its not utilized fully. GPU should be over 60%, preferably over 80% when gaming.
And yeah, x256 is CPU encoding. You should be good on either, and this feels like driver issue since its happening on both recording and streaming.
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15144910
Hey,
it seems I will end up using x264, it can stream 1080p60fps without any issues, while nvenc new could not even stream 720p30fps 😄
Do you have any clue why nvenc has these issues?
Thank you for your assitence by the way 🙂
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15145060
10 hours ago, qvtran said:
Hey,
Like I said, drivers. Could be one version with issues, but could be more serious issues with GPU as whole. Hard to say, but I think we've pinpointed where the issue is.
https://linustechtips.com/topic/1393379-streaming-problems/#findComment-15145794
