static pressure fans are more optimized for pushing airflow that goes through an obstruction, eg radiators, hard drive cages. hence why they have a bigger surface area on the blades. air flow fans are just for airflow with no obstruction.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
So wouldn't that mean that for the same purpose (pushing air in/out of case) they would be better than Air flow fans?
Loves PC Games :D
it depends, from what i've seen on forums, air flow optimized fans tend to push more air as they have a higher cfm in an unrestricted space. static pressure is generally designed for heatsinks and radiators with a lot of resistance to the fans.
but it's up to you, whatever floats your boat
Old Rig
