Pa_5262426
Welcome to the forums!
First try clearing your CMOS - remove the coin cell battery on your motherboard, leave it out for about 15 minutes, put it back in, try to boot.
Then try taking all of your RAM out, blow out the slot with air cleaner. Do the same for your PCIe cards.
Well I assume you have a motherboard from 1995 and you prob need to replace it 🙂
Nice way of saying we need more information than it dont worki
and try to clear cmos
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
I find that one stick of RAM sometimes goes insane, and needs to be quarantined. Try (if u do have more than one) taking one out, plugging it back in, and trying it. That doesn't work? switch it out with the other one. A simple thing to try. I second the idea of taking them out and putting them back in, this sometimes works too. Cheers!
30 minutes ago, Tan3l6 said:
Specs?
Tried clear cmos already?
No, but I didn't overclooked
33 minutes ago, Pa_5262426 said:
I played a game and then my Pc suddenly went out. When I try to start it, the fans turn for only a very small piece. The LEDs on the motherboard are on. Can sb. help me pls.
Sry that I didn't said the specs:
b450 f-gaming asus, rx 590, ryzen 5 3600, 8gb RAM in all 4 channels. And I didn't overclooked so far.
Thanks for any help
Sorry, the specs are listed know in the question
Brand and model of the PSU and RAM?
BIOS version installed on the motherboard?
36 minutes ago, Tan3l6 said:
Specs?
It's a good "remedy" to try it anyway..
I edit my posts more often than not
1 minute ago, Pa_5262426 said:
Rx 590 fatboy xfx
That's the GPU. It's the PSU I wanna know.
2 minutes ago, Pa_5262426 said:
8gb RAM sticks in each channel (32gb)
Brand and model?
Ok thx I will try it
Brand and model?
Yeah sry I was tierd. I have the RM650 Corsair.
Brand and model?
And the RAM is the corsair vengeance LPX (3200MHz)
Brand and model?
Thank you for helping me out and sorry for my mistakes I'm new on the Forum.
Take a look at the label on each stick. What's the exact model number? And there's a version number written on the sticks next to the voltage. Something like ver 4.32. What's the version number of each stick?
