Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
https://linustechtips.com/topic/1392226-help/
What CPU is that? Since it's AMD, it needs to end in a "g" to output graphics. Like the 5600g or 5700g. If it's not a "g", you need a graphics card.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1392226-help/#findComment-15129175
11 minutes ago, xXxjosh44g said:
It’s the amd ryzen 5 5600x
Then you need a graphics card. 5600x doesn't have integrated graphics.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1392226-help/#findComment-15129221
