I'll keep it brief since I have a rough idea where the problem might be, but it still baffles me so I'd like to know if anyone had that happen and found a solution maybe.
Long story short, I got a suspiciously low priced i7 7700k to replace my i5, and astonishingly it was doing fine, maybe not the peak of it's kind but still pretty good.
That is until I put on the heatsink, the moment any preasure other than the mounting thingy on lga 1151 is applied to the chip, and not even a lot of preasure, the passive weight of my heatsink is enough to make the processor just go litellary insane.
It starts generating memory errors, occasionally crashing the whole machine and generally slowing down.
Is there any explanation for it besides "I guess silicon is just quirky like that sometimes"? I don't even hope to recover the chip, I just want to know what happened to it.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/
No way we can know, but could be anything from a PSU catastrophic failure damage to a pin break and reattach, who knows?
You just got sold a bad CPU sounds like.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15128966
Well I'd be able to test another psu, but I ruled that out since putting the heat sink on worked like a magic trick, I could litellary put it on mid memory test even without properly bolting it on, without any contact points besides the cpu itself (so I'm sure no shorts on screws happen), would cause it to instantly spew errors left and right.
It's not old enough to have pins, it has pads and the old cpu works perfectly on the same board, so it really baffles me.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129019
Yeah, I was completely guessing.  Since you acknowledge you bought it for a shockingly low price.... kind of clues you in up front.  It's busted, someone unloaded it on you.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129023
1 minute ago, emosun said:
How were you able to test the cpu without a heatsink
I shortly removed it since I was out of ideas, I know it doesn't sound too bright, but the mounting mechanism holds it well enough for it to run fine before it manages to heat up.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129028
Just now, emosun said:
So you ran the cpu without any heatsink on it and now it doesnt function
Well not entirely, of course I didn't pop that bad boy (litellary bad) in with no cooling to begin with, I only found it out after a bunch of testing since I though of stuff possibly shorting on it.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129034
Ok well it should be said you never run a cpu without a heatsink not even for diagnostic  purposes. So whatever initial issue you may have had has now become several issues. If the cpu was ran without the heatsink theres no telling what damage has just been done to it vs whatever damage some other component may have had. So your current varible now includes the cpu itself which is typically the most reliable component on a pc.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129076
Thanks for the critical look, I'll keep all of that in mind next time I get to touch a cpu.
If it was faulty from the start I still didn't exactly solve anything and did introduce more potential problems.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129138
Well the idea is the cpu may have been fine and the motherboard or socket or power may have had an issue using that cpu
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129142
Yeah was a lil hasty to assume if the old one worked this one has to.
Just in case I happen to get it working someday or if it'll turn out my other components are somehow to blame
I admit I'm not a smart man in advance.
https://linustechtips.com/topic/1392194-bizarre-cpu-problem/#findComment-15129172
