I'm trying to install Windows 7 64-Bit off of a disc, it's been giving me an x64 Exception Error with a ton of numbers listed after that.
My specs are:
AMD Phenom II 965 BE
MSI 890GXM-G65
Crucial Ballistix 4GB DDR3-1333
Seagate Barracuda 500GB
ASUS GTX 550Ti
I would appreciate if someone could help me, I've been trying to do this for a few hours but haven't been able to find anything online.
https://linustechtips.com/topic/1392-x64-exception-error-help/
With that being a older CPU it might not be a 64 bit CPU' date=' but not too sure, I suggest sending an email to AMD and ask them if your CPU is rated for X64 OS[/quote']
The processor is x64 compatible: http://products.amd.com/pages/desktopcpudetail.aspx?id=591&AspxAutoDetectCookieSupport=1
https://linustechtips.com/topic/1392-x64-exception-error-help/#findComment-19127
It is rated for 64 bit, it's listed on multiple websites as such, and I actually had windows running on it before, but have to re-install after replacing the hard drive.
https://linustechtips.com/topic/1392-x64-exception-error-help/#findComment-19129
Download Memtest86 and burn to a CD on another computer. Run the program (no OS needed) and see if you memory is OK. Memtest86 Download: http://www.memtest86.com/
Thanks for the suggestion, I will be trying this, I will report back when its done!
https://linustechtips.com/topic/1392-x64-exception-error-help/#findComment-19195
You do that! Will be fun to see if im right.
https://linustechtips.com/topic/1392-x64-exception-error-help/#findComment-19201
