It comes with 1.
$35 for how many fans?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
I'd get 2 140mm Pure Wing 2's for intake and use the stock fan for exhaust. You can also get Arctic fans, they're great value too. Noctua fans are also great but not very budget friendly.
If you want RGB some Cooler Master MF120's are also great, but they're 120mm which isn't as good as 140mm.
