n00b needs help - CPU/RAM Compatibility Warning
59 minutes ago, Lord Nicoll said:If it's gaming Intel's Alderlake is usually ahead and is a pretty good arch for a lot of things but it's a little hot and a tiny bit of a powerhog
Alder lake power consumption in reality
Though atleast this time it has good performance unlike some other waste of silicon (looking at you 11900 cpus)
On 11/25/2021 at 4:14 AM, Lord Nicoll said:If you want it to be relevent for as long as possible wait for the new AMD CPUs to drop as the 5950X was released over a year ago. Rumours suggest probably coming in early 2022, or go with Alderlake, it's pretty alright, but I'd wait to see what the to be announced AMD stuff is like.
Alderlake is still really young and the acritecture is very new so theres gonna be some growing pains
Zen3 is still more efficient than alderlake but does lose out in performance quite abit, not to mention zen 6000 or whatever the hell theyll call it this time is gonna release pretty soon
On the pcpartpicker list
Cooler is some overpriced trash for a tiny ass display, if you want a display on your pc look at installing one of those sensor panel thingys, you could use it as a sensor panel or a glorified picture display, not to mention it isnt tiny asf
Ram is ludicrously overpriced, id suggest ripjaws v 4000 cl18 cause 32gb kit for that is ~135, also after looking around for the highest ddr4 volts i could find, looks like the deathzone for ddr4 is ~2v, so i think upto ~1.7v is prob "safe" but you prob wont need to push those volts that high unless you got some good ram dies that scale well with volts
Evolv x doesnt seem to have much front airflow but instead a ton of bottom and top airflow, though maybe consider a cheaper case like the enthoo pro (2)
