Have a look at this. It helped me.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/1389675-help-ples/#findComment-15111469
You probably meant the RM? We would need more info, for example the system specs. You should try the tier list above, it should give a good idea what is good and what isn't. Usually the best PSU's are above 80, but maybe you can find a decent deal with black friday if you can wait. I'm sure the RM series will go on sale, they are on sale pretty often (I got my RM650x for 70 during a sale)
Just now, shoutingsteve said:
NEVER buy a used power supply.
Who says it's used?
https://linustechtips.com/topic/1389675-help-ples/#findComment-15111484
51 minutes ago, shoutingsteve said:
oh, good lord.  you meant US Dollars, not "used."
shit it may as well be at this point
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1389675-help-ples/#findComment-15111586
