Terrible temps
Go to solution Solved by Matt75_,
Huge update: I moved my ram from the second slot to the last one and now the cpu temps are perfect. Max 55c° after 30 min of aida 64 stress test.
Hi everybody, I hope this is the right place to ask this question: I upgraded my cooling solution some month ago and now my temps are really high.
I have an i5 9400f and before i used the stock cooler with temps around 84c under full load. Now my cpu arrives at 100c under full load. It doesn't turn off and it doesn't throttle. I'checked the pump and it works. I've repasted it and mounted it in a different position. What should i do ?
I have a kraken 53 now btw.
https://linustechtips.com/topic/1389467-terrible-temps/
Are you sure the fans are spinning? If not check if they are plugged in, if they are spinning check what fan curve they are set too and if there is enough space in the case for them to pull cool air through. The only other things I can think of is that the thermal paste application is not enough. the cooler is defective or the heatsink is not seated right.
https://linustechtips.com/topic/1389467-terrible-temps/#findComment-15109971
The 9400f is easy to cool.
If the pump is working, it's probably a bad mount. What's the thermal paste spread look like?
Try reseating it and making sure that the cooling block is fully and gradually tightened in an X-pattern instead of one side before the other.
https://linustechtips.com/topic/1389467-terrible-temps/#findComment-15110195
