Can someone help with unexpected unindent Python?
Go to solution Solved by RockSolid1106,
Would be great if you could post the error here. It tells the line on which the error was found, and that is helpful.
Anyways, I found some errors in the code, which I've fixed. Also added comments to help you understand.
Posting some compare screenshots to help you understand better.
Corrected code:
import time
import requests
def get_random_quote():
    try:
        response = requests.get("https://quote-garden.herokuapp.com/api/v3/quotes/random")
        if response.status_code == 200:
            json_data = response.json()
            data = json_data['data']
    except: #missing except statement here, added.
        pass
print("Tere!")
time.sleep(3.5)
print("Ma olen teie vrtuaalne assistent.")
nimi = str(input("Mis on teie nimi?"))
print(("Tere, ") + nimi)
vanus = str(input("Kui vana te oled?"))
print(nimi + (", teie vanus on ") + vanus + ".")
hinne1 = input(nimi + (", mis on teie esimene hinne?"))
hinne2 = input(nimi + (", mis on teie teine hinne?"))
hinne3 = input(nimi + (", mis on teie kolmas hinne?"))
vastus = ((int(hinne1) + int(hinne2) + int(hinne3))/3)
print(nimi + " sinu vastatud tulemuste järgi, sinu keskmine hinne on " + str(vastus))
if vastus >= 4:
    time.sleep(3)
    print("timm")
else:
    time.sleep(2)
    print("jamps")
if vastus > 5:
    time.sleep(3)
    print("kuid oled häkker!")
time.sleep(2)
print(("Sinu andmed on: ") + nimi + (", oled ") + vanus + (" vana ja sinu hinnete keskmine on ") + str(vastus) + ("."))
time.sleep(2)
kas_õige = input("Kas teie sisestatud andmed on kõik õiged?")
if kas_õige == str("jah"):
    print("Hästi, te olete sisestanud kõik teie andmed õigesti!")
else:
    print("Kahju, kuid oli hea teiega kohuda!")
tsitaat = input("Kas te tahate saada suvalist tsitaati?")
try: #You can't use except without try.
    if tsitaat == str("jah"):
        print(data[0]['quoteText'])
    else:                                       #the else and except statements were indented for some reason, which I have fixed.
        print("Tuli viga tsitaadi saamisel!")   #
except:                                         #
    print("Midagi läks valesti! Proovi uuesti!")#
#also removed the else -> while true continue loop, which prevented the code from executing further.
vastus_lõpp = None
while answer not in ("jah", "ei"):
    answer = input("Kas te tahate vestlust lõpetada?")
    if answer == "jah":
          #missing code?
          print("Missing code here")
    elif answer == "ei":
         break
    else:
        print("Palun sisestage, kas ei või jah.")
#Programmi lõpp
time.sleep(3.5)
while True:
    print("Näeme varsti!")
    time.sleep(1.5)
    print(("Head aega, ") + nimi + ("!"))
    time.sleep(2)
    break
Hope this helps. I'm not sure if this executes, because I don't have the appropriate packages, and the language, which I can't understand.
import time
import requests
    try:
print("Tere!")
time.sleep(3.5)
if vastus >= 4:
    time.sleep(3)
    print("timm")
else:
    time.sleep(2)
    print("jamps")
if vastus > 5:
    time.sleep(3)
time.sleep(2)
time.sleep(2)
else:
        else:
        except:
else:
    while True:
        continue
vastus_lõpp = None
    if answer == "jah":
         break
    else:
#Programmi lõpp
time.sleep(3.5)
while True:
    time.sleep(1.5)
    time.sleep(2)
    break
Tere! I'm not a python developer, but checking syntax, it looks like an issue arises when you check for an affirmative answer ("jah") and do nothing with it.  Python syntax appears to expect something there.  Though, that may have been edited out.  Not sure.
41 minutes ago, GroovyFN said:
    if answer == "jah":
	continue
        break
    else:
Looks like you need to also be really careful with your indentation with Python.  Which, as I recall, is why I don't use it.  Sometimes I'm a bit careless with indentation, and figuring out those errors is incredibly frustrating.
-Edited-
Please use code tags
Corrected code:
import time
import requests
    try:
        pass
print("Tere!")
time.sleep(3.5)
if vastus >= 4:
    time.sleep(3)
    print("timm")
else:
    time.sleep(2)
    print("jamps")
if vastus > 5:
    time.sleep(3)
time.sleep(2)
time.sleep(2)
else:
except:                                         #
vastus_lõpp = None
    if answer == "jah":
          #missing code?
         break
    else:
#Programmi lõpp
time.sleep(3.5)
while True:
    time.sleep(1.5)
    time.sleep(2)
    break
On 4/5/2024 at 10:13 PM, LAwLz said:
I am getting pretty fucking sick and tired of the "watch something else" responses. It's such a cop out answer because you could say that about basically anything, and it doesn't address the actual complaints. People use it as some kind of card they pull when they can't actually respond to the criticism raised but they still feel like they need to defend some company/person. If you don't like this thread then stop reading it. See how stupid it is? It's basically like telling someone "shut the fuck up". It's not a clever responsive, it doesn't address anything said, and it is rude.
MKBHD is but an Apple propagandist and fanboy. Take his videos with a grain of salt, especially about anything Apple. In his video titled "I Visited Apple's Secret iPhone Testing Labs!", he has shown that he makes no effort to fact check Apple's claims, and takes it at face value. I do not believe he can be trusted as an Reviewer/Influencer.
bruh switch to dark mode its at the bottom of this page
VPN Server Guide
