Airflow and watercooling
Go to solution Solved by IronCross187,
Depends on the rest of your fans. I turned my inwards to cool the CPU and motherboard, with a side fan pulling air out away from the CPU and motherboard, and a final fan pushing air in at the front.
It could make a small difference or none at all, you may as well experiment with it and find the best configuration.
Should I turn my outward or back fan to face into the case so that more air travels upwards towards my Corsair H100i water cooling 120mmdual radiator ?
[spoiler=My Beast Rig Damocles]Case: Coolermaster Storm Stryker Motherboard: Asus x79 deluxe CPU: Intel I7 4960x @3.6GHz (soon to be oc) RAM: Kingston HyperX 64GB @2400MHz GPU: Nvidia Geforce GTX 770 (Gigabyte) @4GB PSU: Corsair RM1000 Fully modular CPUCooler: Corsair H100i Watercooling Storage: Seagate 2TB SV35.6 SATA 6GB/s 7200RPM 64MB 3.5"   x2  Sound: Creative Soundblaster ZxR sound card
This is my old pc which I am reamending to be a media server or a nas. Motherboard: Generic fujitsu CPU: Intel pentium G640 @2.8 GHz RAM: 4GB generic fujitsu memory PSU:  CPUCooler: Stock intel cpu cooler Storage:  Fujitsu MHZ2120BH @120GB, Soon to have a HDD for more storage.
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/
I turned mine around and it dropped temps a bit I really depends how much your pushing your H100i with my 8350 in the 5Ghz range its needed for the extra airflow
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1852246
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1853603
well i do have around 8 fans in my pc well going in since this is a new build i will be using a I7 4960x overclocked to around 4.8 if possible (>implying i am new and have never overclocked before but will use the tpu switch on the asus x79 deluxe board) so the only 2 outward fans will be my H100I radiator fans
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1858111
Get a costum loop instead, or just send me the 4960x :) and I'd go with h110 instead if you still just want a prebuilt cooler and change the fans because they are noisy
Emmh... Maybe consider killing yourself before you talk to me?
Pople on this forum though some of them had a brain, turns out, no.
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1858196
I have changed the case fans to Coolermaster Sickleflow120mm fans @2000RPM with blue leds. sound is not a concern to me. Also don't be a cunt and ask for a 900+ euro (I am from ireland) cpu which I recieved in a horrible state as it is. if i were to send it to you it would make you pay 5000 that's 5 times the price i paid so "Do you feel lucky, punk?"
also you spell custom as "custom" , also it's a H100i
You should have air coming in from the front and out though the back. However you might want to have the top as intakes to create positive pressure and reduce dust build up.
Also nice pic btw.
were you saying my pic? or bamer's?
Into, extra airflow for that H100i. I assume the front fans are intaking air?
yes they are i have nearly every possible fan mounts as intakes
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1858512
Yours
Thanks it's from when i played comp tf2 as sniper (I miss being a twitch sniper) :'(
It was a joke mad guy <(•_•)>
I don't take jokes on something that i nearly had to send back because it was in such bad state i had to bring it back to life after paying over 900+ euros for it and there wasn't any i could buy in europe that i could get within a week
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1859431
There's almost no online store that takes less than a week to ship in Europe and you didn't say that story before I said send it to me.
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1859582
then why are you still here?
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1860384
Damn I feel fucking sorry for your mom/dad.
.-. wut?
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1860654
soldier main myself, haven't played comp yet, play a lot of mge and tf2center.
I'm a roamer soldier myself atm and kinda kept some of my twitch skill for scout but I really need to get back into sniping but my isp is a bitch and locked down my bandwidth so every server I go on is like 200+ ping :'(
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1864629
Feel for you. #CryForD0n :'(
Twitter | Steam |
https://linustechtips.com/topic/138920-airflow-and-watercooling/#findComment-1865458
