Help with installing liquid cooler?
Solved by Skiiwee29,
what Motherboard? Typically though RGB headers are white and are either 3 pin or 4 pin. Your connector from your Pump is a 4 pin, so it needs to be plugged into a 4 pin header, otherwise you will burn out the 3 pin since its only 5v and could damage the rest of the board potentially as well.
EDIT: If its the B550 Tomahawk in your signature, There are 2 4 pin RGB headers, one is in the bottom left next to the Front Panel Audio connector Labeled as JRGB 1.
2nd is above the USB 3 header JRGB2:
