Hello, I was wondering if anyone could recommend me something for a dual cpu 4+4 pin converter. I have an rm850x and a 3070ti Aorus Master and the only thing I forgot to check was the PSU slots. I need help finding a decent quality 4+4 pin dual CPU cable that is reliable and about 70cm long. Thanks in advance
https://linustechtips.com/topic/1387653-help/
Is that something you would be looking for?
https://www.bequiet.com/de/accessories/1448
if yes, there should have been one in the box, according to corsair.
Corsair: EPS/ATX12V 8 pin (4+4) cable
Cablemod offers the cable for 20USD, as a custom cable. They seem reliable enough. In the end i suggest whatever cable you buy, to measure wire resistance and perhaps voltage drop with a constant load.
I wouldnt reccomend splitting the 8 pin to 2x8 pin... most likely youll be running out of spec then.
https://linustechtips.com/topic/1387653-help/#findComment-15096414
it should come wit those already.
or is the cable too short?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1387653-help/#findComment-15096513
2 hours ago, --SID-- said:
You lost som cables? The 2018 version comes with two 8 (4+4) pin CPU cables and the 2021 version with three.
Very sorry, forgot to mention it was the 2019 version, I do have both the 8 pin cpu cables but I was just wondering if there was any ones that connected to one slot but has dual splitted CPU cables
https://linustechtips.com/topic/1387653-help/#findComment-15096644
On 11/12/2021 at 12:40 AM, --SID-- said:
That's RM, not RMx.
Very sorry, I have a terrible memory,
it is this one,
https://www.scorptec.com.au/product/power-supplies/atx/92069-cp-9020200-au?gclid=Cj0KCQiAhMOMBhDhARIsAPVml-HUis_X7QaJputuy6K40CDr-zLWNy1vFyK6ePGT7rVKgWGVtCRDPcMaAqb-EALw_wcB  Not sure where I got 2019 from but none the less
https://linustechtips.com/topic/1387653-help/#findComment-15101842
