no post and cpu debug light (2nd mobo)
Solved by -rascal-,
@Hachi_Roku256563might be onto something.
For that motherboard, BIOS version 7B85v26, or newer, must be flashed onto the motherboard before the 5600G will be recognized.
Do you have an older CPU/APU available to perform the BIOS update?
Oh the motherboard, also has a 'Flash BIOS' button / feature, so you can update the BIOS without a CPU installed.
Make sure you follow the steps on how to flash the BIOS "headless" properly.
https://www.msi.com/Motherboard/support/B450-GAMING-PRO-CARBON-MAX-WIFI#support-cpu
