8 minutes ago, FrozenTvDinner said:
Hey does anyone have a 3070 FE Fan that i could buy? i was cleaning mine and the thin a$$ cable tore on one of the fans.
you sure it isn't fixable? where is the break at? pics? a quick search turned up nothing for me for an oem replacement.
https://linustechtips.com/topic/1387094-3070-fe-fan/#findComment-15091548
5 minutes ago, FrozenTvDinner said:
Yeah it sucks but lessoned learned lol
found these on alliexpress, not sure if i would trust them though. https://vi.aliexpress.com/item/1005003226554034.html?spm=a2g0o.search0304.0.0.5837542dRAWqcI&algo_pvid=c955f990-c5eb-409f-9790-3e6ec3fdd204&algo_exp_id=c955f990-c5eb-409f-9790-3e6ec3fdd204-3
https://linustechtips.com/topic/1387094-3070-fe-fan/#findComment-15091575
1 hour ago, bmx6454 said:
Yeah, just thought i might find it cheaper and alot quicker shipping then Ali. lol
https://linustechtips.com/topic/1387094-3070-fe-fan/#findComment-15091711
