I need your opinions [Pre-Built PC]
Solved by Quackers101,
8 hours ago, MiggyAngeloP said:I kind of want to go with the 3rd one, the Shogun, just not sure if it'd be good for gaming and programming, I've never used AMD, reviews in YouTube says it's good for work stuff but intel's better in gaming. GPU doesn't really matter to me, as long as it's RTX
that is the only build without RTX and DLSS? (nvidia RTX GPU).
AMD is good, but on the GPU side they lack various gaming features and raytracing. However they can push more FPS in some titles were these features "dont matter" or as much.
oh yeah forgot, 5600x on the 2nd option, can leave some features locked or whatever on older motherboards like the 450. But it depends on the motherboard and needed BIOS updates.
