New mounting hardware is necessary, you can just google "cooler name LGA1700" to see announcements on their compatibility. 12600k does produce quite some heat though, so follow cooler recommendations for the old 10900k/11700k if you arr going to overclock
Desktop benching:
https://linustechtips.com/topic/1386137-12600k-cooler-options/#findComment-15084816
 Noctua NH-D15 would be my choice but those brackets i can't find anywhere listed
https://linustechtips.com/topic/1386137-12600k-cooler-options/#findComment-15084822
https://noctua.at/en/intel-lga1700-all-you-need-to-know
You just need a proof of purchase to get that sent to you by Noctua
Desktop benching:
https://linustechtips.com/topic/1386137-12600k-cooler-options/#findComment-15084855
