hi my cpu fan is super loud and uncontrolable the stock amd cooler was loud but then i got one that was supposed to be quit and it still was loud. its running at about 2400 rpm and i think the problem has something to do with the voltage but i am not sure and i have tried using the default fan control from the bios but it doesnt change anything and neither does any exteral software. my cpu does keep very cool tho :D
thanks for helping me out!
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/
Are you using the right fan header? What mobo, what cooler?
System Specs: (Click Expand)
          "Beatrix"
  • CPU AMD Ryzen 7 5800x3D
  • Motherboard GIGABYTE X570 I AORUS Pro Wi-Fi
  • RAM 2 x 16GB Corsair Vengeance RGB Pro @ 3200mhz CL16
  • GPU Gigabyte Eagle RX 6700XT
  • Case Corsair Crystal 280x
  • Storage 1x Samsung 980 Pro (1TB) 1x Samsung 970 Evo Plus (500GB) 1x Samsung 860 Evo (1TB)
  • PSU EVGA G5 850W
  • Display(s) 32" Odyssey Neo G7 & 27" Viewsonic XG2705
  • Cooling Corsair H100i Elite Capellix AIO | 4x QL120 RGB fans | 2x QL140 RGB fans
  • Keyboard Logitech G Pro
  • Mouse Logitech G502 Lightspeed /w Powerplay
  • Sound Logitech G Pro Wired
  • Operating System Windows 11 Professional 23H2
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076420
So, which header is the fan lead plugged into? Is it next to the CMOS battery or next to the DIMM slots? Is it plugged in the correct way? The manual states you should ensure the black(ground) cable matches the connector ground, which I'd assume is marked.
          "Beatrix"
  • PSU EVGA G5 850W
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076438
well
well its plugged in right here and the cable is 4 pin and the connector is 4 pin and there is only one way to plug it in so its correct
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076441
Do you have any other 4 pin fans around to plug in and test? Goal here is to determine if it's perhaps a fan issue, or motherboard issue. Plug one into the CPU fan header to avoid the CPU fan error message and plug your cooler fan into the chassis fan header and attempt to adjust speed through that header.
          "Beatrix"
  • PSU EVGA G5 850W
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076449
Please be sure to quote me in your reply so I get a notification. God speed and good luck.
          "Beatrix"
  • PSU EVGA G5 850W
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076454
Isn't it rather so that a fan at 2400rpm will be loud as hell, any fan... ?
-Scott Manley, 2021
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076545
Nope, ATX fans are 12v. If you were to use a 5v fan at 12v, at best it would burn itself the moment it received 12v. If the problem here is fan speed not increasing with CPU temperature, your issue is with either fan control settings in bios or the fan itself. Check if fan all wires going into the fan are connected on the fan side (not the connector).
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076552
1 hour ago, Mark Kaine said:
On what planet is a 2400rpm fan not loud lmfao.
Different standards of noise, once you get used to silent PCs, you notice maybe? Idk...
          "Beatrix"
  • PSU EVGA G5 850W
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076601
3 hours ago, Mark Kaine said:
honestly I think by buying such a high rpm cooler you exchanged a lemon with a grapefruit...
My Noctua goes from 500 to 700rpm or so and is near silent
  Reveal hidden contents
(that's when it's not deciding to randomly rattle like a tractor,  i think the fan has a manufacturing defect or something  👀 )
yeah so its just that for some reason i am getting crazy high rpm without being able to control it
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076722
Yeap, i got that, what did you try to control it? Did you set a fancurve in bios? Did you apply it? Can you control other fans through bios?
Otherwise you may try fancontrol.
https://linustechtips.com/topic/1099996-fancontrol-my-take-on-a-speedfan-replacement/
Edited by Mark Kaine
-Scott Manley, 2021
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076727
well i have tried to use the fan control form my bios but it wouldnt make a differance
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076733
Yeah, check my edit, can u control other fans ?
Otherwise,  try fancontrol (i put a link above)
2 minutes ago, ShrimpBrime said:
The board controls the fan based off cpu temps.
Yup, but it doesn't work on some boards (mine only started working after several bios updates, thanks msi!)
-Scott Manley, 2021
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076737
ok so i just tried switching my cpu fan to my chasiss fan port and it got significantly silenter but still ran at the max rpm of the chassis fan port
and when i just booted it showed me the american megatrend screen with the quote "cpu fan error" but i think thats because my cpu fan wasnt in the correct port
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076738
I have the same board as OP, just not the same cpu though. Didn't have any problems with it.
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076740
thanks i think it will help but i just have to try it i guess
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076741
1 minute ago, ShrimpBrime said:
There isn't any software outside the board manufacturer to control the fan.
You can try F6 in bios. Can raise max temp threshold only to 75c.
ok and ill check and see if there are any bios updates
https://linustechtips.com/topic/1385149-cpu-fan-uncontrolable/#findComment-15076759
