Using Two gpu in laptop
Solved by RONOTHAN##,
1 minute ago, Orbf said:My point is can I make my laptop use both gpu?
Also I am interested in question, can anyone use two gpu same time in laptop other than GTX 970?
In certain rendering circumstances maybe, but the workload needs to be specifically designed to take advantage of multiple GPUs of different models. You could also have each GPU dedicated to a different thing.
But for gaming, nope. SLI is the way you use more than one GPU, and it's not compatible with what you're doing, and nothing supports it anymore.
There are laptops that came with SLI GPus, but they're rare, had horrible battery life, and since nothing supports SLI anymore, practically pointless.
