Invisible LED suggestions
By
DNick89
in Cases and Mods
in Cases and Mods
Solved by scaryjam823,
I though about those, but since it goes into a pci slot, I ruled them out.
If that bothers you, you don't have to put the thing in the pci slot, You can run it from behind the motherboard tray and just hide it there. It's only so you can easily change the brightness and turn them on and off, which I never mess with anyways.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
