Monitor Pairing
PNXTech
4 minutes ago, PNXTech said:
Hi I Just won a zotac geforce rtx 3080 ti amp holo and was wondering what monitors would be best paired with a GPU of statur.
TIA
PNXTech
Depends on your use case do you play competitive with high refresh rates in games or do you like stunning visuals and high resolutions or somewhere in between?
I'm a multi purpose use case i play mainly D2 (Non-competitive) however I also watch content on it
https://www.bestbuy.com/site/gigabyte-27-ips-led-qhd-freesync-monitor-with-kvm-hdmi-displayport-usb-black/6438287.p?acampID=0&cmp=RMX&irclickid=VIpwSbzAYxyIWExTom1RhQC8UkBS9bRi0ycux80&irgwc=1&loc=RTINGS.com&mpid=1989377&ref=198&refdomain=rtings.com&skuId=6438287
this monitor is pretty damn good for its price decently high refresh rate, good pixel density and nice thin bezels I think this is perfect for your use case a good balance between some gaming and watching videos.
However if you have a higher budget
get this
ASUS ROG Strix 27” 4K HDR 144Hz DSC Gaming Monitor (XG27UQR) - UHD (3840 x 2160), IPS, 1ms, Extreme Low Motion Blur, DisplayHDR 400, DCI-P3 90%, G-SYNC Compatible, Eye Care, DisplayPort, HDMI, USB 3.0 https://www.amazon.com/dp/B09B8WLYGD/ref=cm_sw_r_cp_api_glt_fabc_NHA6XMW0CPR9C47GAKBE
